frankr
I have front and rear disc brakes and my master cylinder is mounted lower than the calipers so,I will be using 2 Lbs residual valves to prevent the brake oil returning to the master and overflow the reservoir. Do I install the valves right at the master or should they go after the proportioning valve?
Thanks for your help RRR.
Frankr
1934 Dodge 392 Hemi [dr
Frankr
