kelseydum
Well, I didn't want to start a new thread on this, but maybe people can find it easier in the search section. I reversed my 64 Mustang steering box today. I went by an article in Ol' Skool Rodz magazine about reversing a Corvair box. The principal is basically the same. It was pretty simple and the hardest part (for me) was getting the shaft nut loose. There was not much lip on the nut to grab onto so I set some vice grips on top of the wrench so it would pull off and I finally got it loose. Once I got that loose I spent maybe an hour on it (mostly because I was taking notes and inspecting parts). If I had to do it again it would probably take half an hour to 45 minutes. Here's what it looks like now... and should work near perfect. If anyone has questions just ask and I can explain more.
I was going place a freeze plug from the inside but that was going to conflict with the bearing. So I'm going to find a smaller one to plug the end (of the old shaft hole). I'm going to find a rubber bushing to place on the new shaft end to help center the column.
