using an S10 frame is great for the wide availability of lowering parts available, but some guys work on a different budget. If you are cutting a coil to lower the truck 2" you might not want to spend $100-$120 a pair on some shorter gas charged shocks and wait for them to ship.
The 1972-1984 Mazda B2000 truck uses the same compressed and extended length as the commonly available S10 short drop shocks, and use the same top and bottom attachments. They are readily available at your local parts stores, just looking online at my local stores I have my choice of Monroe, Gabriel, KYB, standard or gas charged, twin tube or monotube, in stock at prices from $15ea to $45ea.
my recommendation is for a nice gas charged twin tube, usually $20ea. If you dont plan to run a sway bar or just have impossibly smooth roads, the monotube will be a better performance shock for canyon carving, but also more expensive at $45ea.
What about the rear? The rear is usually lowered with blocks, so the shock length does not change.
