i am build on a 46 ford sedan frame...this is an spring forward of the axle....i have taken the spring out of the orgional cross member...plan on making a perch at the very front of the frame...no it seems to me this is called a seucide set up?...with spring forward of the frame...now i have cut my wishbones and with a little heat can spread em'...now if i were to buy adjustable spring perches..new spring...and then new split wishbones...this would run me over 350 bucks from speedway ....it will then be a spring on top of the axle set up......i am on a budget and definitely want a strong and right front end....any suggestions and pics or anyone do this conversion?.....is it even necessary?
