shoebox rear lowering blocks
earthman
Jul 8, 2007
12,442
Rimrock AZ
The shoebox has a hemispherical cup in the spring perch about an inch in diameter with a matching bump on the springs to locate the springs with the axle. I have regular 3" blocks but they are incompatable. I don't see any info on the web about this. Anyone have experience with this? Thanks
could you not have a recess or hole on one side and an emboss or protruding area on the other side of the block to keep it located much like the stock setup did?
http://www.justclassiccarsparts.com.au/images/P/$_20-179.JPG
The aluminum blocks i just bought from Speedway are the typical type with a pin on top and a matching hole on the bottom. Doesn't match the Ford shapes at all. It would take a machine shop to refab these to fit.
The blocks need to be cast specifically for this application and i don't see anyone anywhere discussing this which is puzzling since these cars have been lowered with blocks now for 60 years. Thanks D.R.
