Single post rear light conversion
hotwheels
Mar 7, 2010
324
Wyoming
Okay, i purchased a set of rear lights i want to use as taillights. I took the light apart and found it is a single filimant bulb. I bought the parts to convert this into a dual filimant bulb.
My quesion is, will the 1157 bulb work as a tail, turn and brake light? or do i need to install and 1156 socket too?
tail lights conversion
i happen to be doing the same thing, make sure you get the right bulbs, i bought a set that should have fit but the little nubs on the side of the bulb was offset so i hd to make another trip to the parts store. good luck pal.
The test's i have run so far show that i have it right. Once i get my wiring harness installed, i'll know for sure.....
Write your reply...
