35Mastr
Mastr Blastr
How do you get them in with the text?When I click on them they directly to the title as in this one.And can just get that one that you see.No others anywhere.Is there an option that I dont know about.
If I hit post reply.There is no button to Go advanced??????????Just has Submit reply or Preview post.
35, When you post a reply do you use the Post Reply button or the icon with a piece of paper and a quill on the the bottom right of the post? If you use the post reply button it does not give you the go advanced.
If you use the paper and quill icon you will see the post quick reply, go advance button...or at least you should.
The problem is that there is none on the right.Just the bottom???????????
This is what my page looks like and I would think your's should also.
The smiley icons are circled in red, the option at the bottom that must
be unchecked is also circled.
This is the standard reply page.
If you don't see these items, then check with Tripper to see what needs to
be changed on your set up.
I hope this helps, and you know I had to use the smileys... '22
What browser r u usin'?!
Its weird.I dont have it here or on the Hamb.But I have all that stuff that 22 has on KB.Go figure.
I never even realized it till today.
