meteorman
I'm having trouble getting m brakes working right. the pedal is very soft, it goes to the floor, but stiffens up if I pump it a few times.
It's a new master cylinder, disc front, drum rear. Brakes are from a 78 dodge motorhome. The master is a dual master from Speedway. I have residual valves on the front (2psi) and rear(10 psi) in line. I'm running a proportioning valve in the rear, and have no idea how to adjust it properly.
I've bled the lines, and bled them and bled them. Nothing seems to help.
any ideas? can I run without the proportioning valve? I'm reading that it's difficult to bleed lines with it?
