Well I thought I either had a bad solenoid or bad starter on my Ranchero. I'd hit the key to start it & it would go dead & then the power would come back on (the radio) in a lil bit. I replaced the solenoid ($12) but no go. Although I had a spare I hated to change the starter so I started sanding & cleaning all connections. After thinking about it a lil... I thought... it isn't the starter... it just has to be a bad ground. While messing with the ground cable on the battery I noticed it was loose. I pulled it apart & yep... corroded. I cleaned it up... put it back together & tried the key again. Now the positive connection sparked. Corroded... so I cleaned it up & shazam! Lesson learned... sometimes it's the simple stuff!!!
[S[ddd
