ok, so the bearing in the original speedo seized, so i got another stock, used unit, took it apart and cleaned it, and put it in the dash, no other changes were made. my car has a Turboglide tranny,(not a Turbo 350 or 400, a Turboglide) which is an oddball in itself, i wonder if this other speedo came from a car with a Powerglide, and if that is the problem ( i'll try to find out from the guy i bought it from).
Bonehead, i think you're on the right track, i'll call the local Trans repair shop if they can help.
Gastrick, thanks, you always seem to know where to go.
Bob W, took the unit apart before i installed it and it's spotless.
Cycledog, both are stock original speedos, i'm not sure what model car or transmission it came from, i wonder if that's part of the problem.
thanks again, mo........
