Mutt's37Buick
Front Steer in 1937 Buick
I'm evaluating keeping my spring pockets intact and using suspension components from a 2wd ford ranger or explorer to convert my 1937 Buick Roadmaster to disk brakes and ball joints. Trying to avoid changing the front clip.
The components look like a pretty good match dimensionally. My biggest concern with this conversion is that the Explorer is front steer and my Buick has rear steer. Has anyone out there put a front steer suspension in an old car like this. If so, where did you locate the front steer components?
I'll be changing the straight eight for a V8 so there should be room in between the engine and radiator. Could the rack & pinion from the explorer be bolted across the top of the frame?
Thanks
Thanks
