Late spindles
I did not want to get into this front end because it is ( rebuilt ) I was told it had new bushings and kingpins in it when I bought it, I do have a set of late spindles, but I will have to cut the arms of of them also, to mount all of my steering arms, I need to run the spring behind the axel to get it low enough, and front steering, I guess I could use the late spindles with the arms facing forward and just cut off the extra hole on the one arm, but I would have to run the steering arm from my steering box to the bottom of the left spindle, I have never seen that done but I guess it would work if I could keep the angle right so I would get no bump steer.
I WAS THINGING UPSIDE DOWN, after looking again I see the stock arms would be on the bottom, DUH
