26Troadster
- Joined
- May 22, 2007
- Messages
- 4,078
ok long story short the starter bolt holes are drilled 3/32" out to far. i know i have the 168 flex plate and staggered bolt starter and i have broke the second one now. i can take the th400 off my motor and put a old cast iron bell housing on my motor with the same flex plate and i have no starter problems at all, but go back to the block mounted and it sounds bad.i can take a 1/8" rod between the starter shaft and the flex plate teeth and rattle it. i believe i can use a block plate to a blow shield bell housing between my th400 and motor and use the bell housing starter to cure the problem. what do y'all think about this.
