26Troadster
- Joined
- May 22, 2007
- Messages
- 4,078
ok i'm at witts end on this one. i have a 350 chevy i built about 16 years ago, and i bet it doesn't have 20,000 miles on it because of starter problems. this may get long winded but please stick with me here. from day one of having this motor built i have been at the starter, at first i though it was to close, but the more i shimed it the worst it got. one day replacing a broke starter i was in real tight so i put it on with out the shims so i could get it up on the ramps, it started better. so with in mind i got to checking in some old books i had and found where i could use a 1/8" welding rod between the teeth of the flexplate/flywheel and the starter shaft to check the fit. mine was real loose as you could rattle it. i milled .082 off the starter mount area which doesn't leave alot of meat, and shimed the outer bolt, closer but not enough. on starter number 5 i had the motor out and upside down on a motor stand, new flex plate, new starter, milled about .080. bolt starter on, try shimming, still not enough. take a 9" grinder and ground the starter mount pad on block, get out machine square and sanding pads and relevel the pad and make it square again, now i had to make new starter bolts so the knurle could keep the starter tight, set everything up shims on outer bolt, better fit this time still alittle loose but alot better. motor in car starts alot better but still the best way to crank this motor is to get it spinning and then lite the plugs and hope like hell it doesn't kick back. today trying to start the motor it kicked back and got starter number five. have had a castiron bellhousing behind this motor with the old three bolt bellhousing mounted starter and it starts fine, no kick just a smooth start. when checking the fit with the bellhousing mounted starter the same i check with the block mounted starter and the 1/8" rod is snug. i have been thought about getting the block plate for a lakewood scattershield that has the old three bolt starter mount holes (can't remember the number at the moment) and putting it between my motor and trans and see if that might help, as i do have some of them old starters, but i belive the plate could flex being it is only about 1/8" thick, maybe some struts. i would hate to buy a high price mini starter and as soon as i get it start milling metal off. i really belive the bolt holes are drilled to far to the outside of the block, but i want to keep it auto. i'm open to suggestions.
