Rhynorock
I'm having a hard time doing the math on how to set up my steering column inside the cab. I'll be using the stock steering setup from an S-10, running a length of 3/4 DD shaft from the cab to the box and attaching a steering wheel at the other end. The problem is coming up with a way to secure the column inside.
I was thinking of using a piece of straight exhaust pipe, and tack welding a wheel bearing with a 3/4" inside diameter to the inside of the exhaust piping, feeding the DD shaft thru that, then securing it to the under side of my dash.
Any better ideas anyone? Pictures of your steering setups would be helpful.
