52 fordman
The steering shaft i am using is 10 inches to short. What is the best way to cut it and make it longer?
I was going to use a peice of solid bar i have put it inside the 2 parts of steering tube about 2 inches on each end weld the ends of the tube up with 4 rosets on each tube. grind it smooth for the bearsing to fit over.
All your thoughts and ideas are welcome. The shaft area that is being cut is just round not DD tube. There is not enough area in the DD part.
52 fordman
RUST NEVER SLEEPS
52 fordman
RUST NEVER SLEEPS
