Steering
Darksyde
Nov 6, 2015
124
Calgary, Alberta
So I'm rethinking my steering setup. Really wanted the cowl steering, had a mopar manual box, and everything pretty much built. But the inspection guys here do not like any welding on steering.
Can't do cross steer since I flipped my spindles suicide style due to the travel I need with my bags.
push pull style is still my only option, just need to move the box out onto the frame rails.
Looking for suggestions on a small steering box
Im thinking of trying to use my Mopar box(68 roadrunner) but I cant seem to find a pitman arm for it thats straight or doesnt have the rod end built into it.
Any ideas?
attachment.php
Found this one on the Borgeson site, Saginaw 920042
Used a similar Saginaw years ago, I think it was from an IHC pickup
attachment.php
    99.5 KB
    104.2 KB
Yup inspectors don't like helms. Issue with the rod end built into the pitman is how do you attach it to a tie rod. With a a threaded tie rod end I can thread it into a threaded rod and then insert the tapered end into the pitman. If that makes sense.
    34.4 KB
