pacrat1
Active member
I am planning to build a 51 Studebaker Commander. I see a lot of people using fatman stub, for their build. What are the advantages? I see 1: Remove everything, from fire wall to bumper. Weld in new suspension, weld in motor mounts. 2: Remove everything from fire wall to bumper. Cut off frame. Weld in Stub. Weld in suspension, motor mounts, radiator mounts, and bumper brackets. I plan to put in a small block. It will be a while before I start this project. Is there an upside to whacking off the frame?
