ponchotom89
- Joined
- Jan 6, 2012
- Messages
- 97
OK I think I already know the answer to this question. Is it MANDATORY to use a buggy spring short enough that the end shackles set at a 45 deg. angle? The reason I ask is I`m trying to use the original 37 Ford spring behind the front axle by attaching it to the split wishbones.The shackles end up vertical because it is 40" long. Splitting the wishbones and attaching the ends to the frame make the inside edge (attachment points)40" also.I suspect this would allow the front of the car to "wander".Would installing a pan hard bar solve this? Or are there other problems this set up would cause?
