The PERFECT way to do it is with the tie rod behind. That is the PERFECT way. But with the current trend toward ground scraping cars, sometimes it is impossible to get the tie rod behind. My T is that way, it is so low the tie rod has lots of stuff in the way of it going behind, so I put it in front. As a test one day, I put the tie rod behind (had to pull my headlights off to do it) and drove the car. It drove exactly the same way as when in front, except the tires didn't scrub as bad in the parking lot on low speed turns. Otherwise, it was the same, so I put it back in front.Yes, you can pull your perch pins and turn the whole axle around, there is no front or back to an axle. Or, you can simply put the right spindle on the left and vice versa. Of all the suspension sins you can commit, getting screwed up ackermann is the least sinful. Caster and camber are not to be ignored, but ackermann really only comes into play when you turn the wheel, especially on sharp, low speed turns.
BY th way, isnt ackerman that football player for dallas? Whats he got to do with my steering?
I had to swap my Ford spindles side to side and put the tierod in front because with a 4" drop axle the tierod wants to be right where the radius rods are. I read in Speedway catalog to heat and bend the steering arms but man, it would take a lot to clear. Is this why people use split wishbones?
But im not worried about its a rat who needs to turn sharp huh.
thanks Don that is the same way im setting up my front end, but im not sure my steering box will work what are you using
thanks
Jason
