bigd4xman
Active member
I've decided to run a suicide front spring setup with the 37 bones and axle I have and tuck the axle back under the very front of the frame horns. I need to know WHAT SIZE PIPE or TUBING and what WALL THICKNESS I need for using the crossmember as the spring mount. I am going to retain the stock crossmember for extra torsional rigidity and for the radiator mounting location and good place to build grille mounts.
