OK, I'll try to make it short. I've got a 85 Cutlass frame to Z on both ends so it will lay frame. The frame rail toward the back sits higher off the ground than the front when it's at full drop by about 1". I need the new rails to sit flat.
Should I plan on making the back and front level when welding it up OR leave them at the angle they are at? Do I make any sense....
Steering geometry wise, will that 1" rise over 80" make any real difference? I think it comes out to about 1/2 a degree. I'm guessing since I'm using bags I can adjust for that.
How about welding wise? Will it be a bigger hassle one way or the other?
(Haven't found the right guy to weld it up yet, but trying to get it all straight in my head too.)
I nned to update my build....
