DougnDog
Hey Guys
for all of you that have been following my build yesterday was to be test ride day... BUT I ran into a problem, the engine runs very good but the clutch will not disengage. it has a hyd throwout bearing. the pressure plate I used is a flat type I thought it had enought travel but the fitting on the throwout bearing hits the pressure plate before it dissengages so.... the engine needs to come out so I can change pressure plates. boy what a stupid costly mistake. one of my son-in-laws said look at the good side its not all greasy. with his help we should be able to change it out in a week. it goes to show plan all you want but sometimes you hit a bump in the road Doug
