Th350
DozerII
Sep 4, 2015
4,777
Saskatchewan Can.
Never had much to do with transmissions other than taking them out and putting em back in. On the TH350 in my Essex the kick down cable ended up out of adjustment because I changed travel on the go pedal. It has a little ball crimped on the end with a plastic cap pushed over. How do I go about adjusting it to work properly again?
Thanks for any help.
This is a release button, push it and the cable will extend to its maximum length then, simply get in the vehicle and push the go pedal to the floor, let off and it's good.
Thanks OI that's a different set up than mine. Mine goes from the trans through a holder in the fire wall then into a second hole in the gas pedal arm just below the throttle cable.
