This is princess!
lowbudget50
Sep 23, 2012
6,111
6 months ago I bought another 79 bronco. I think it has been seen here in my redneck rotisserie thread in the shop tools section. Definitely not the normal build on here but I thought I would share if y'all Wana see it.
This truck is called princess cause she was a pavement princess, build for mall crawling in the 90s hahahaha. Here are some pics of when I got it and one of it in its hay day.
I ended up buying a spare body that had some parts I needed. Bought it swapped out the parts and sold it for what I payed for it!!!
Body was but on the rotisserie and the bottom was sand blasted completely clean. It will be paint matched. No under coating. after the sand blasting I coated the interior of all the body structures to prevent rusting
It had 2 small rust spots in the floor and we found a few more as the body was stripped m nothing we couldn't fix.
Frame was stripped and sent to powder coating
The body was sent to paint and worked over. Surprisingly it was in decent shape. All cars of this era have rust, but it wasn't out of control. It was taken down and brought back up with great care by the painter. As of right now it is in primer on the exterior and the interior and underside are painted along with some of the small parts
I tore the rear axle down and fixed all garbage welds and wear and tear on it. Also tore the tcase apart and checked it out. New seals and a good scrubbing then a nice coat of paint. Finished the rear axle in black also with a set of disc brakes
Also got out the new powder coating system I bought from Eastwood. Bought some color matched powder. Looks good and easy to use!!
Love these Broncos, nice to see you giving it the full treatment. Boy, the rear diff must have really been flopping around to wear such grooves from the U-bolts, I guess it had big lift blocks. Are you going to change the rear setup or add some extra links to keep the diff from rotating again? Great work as always!!
Thanks zz, I'm excited about this build. I will dig up pics of the lift blocks hahahahaha. It was special. It had a lift block with an aluminum wedge for angle. Then it had u bolts that were too long. They had black pipe spacers on top to take up the slack of the u-bolts. The aluminum wedges started to fall apart making things more loose. It was a hillbilly mess hahahahaha. The spring pads I made are 3" overall longer. Then I ordered a a 4" lift that is all spring. It will be stiffer than a block and stock springs. That's my hope anyway. If not I will build something to help out.
