You've brought up a sore spot for me. 7-wire RV wiring and plugs are really annoying and usually all different. The seven wire cord that I'm used to has a white wire[ quite often bigger] for ground and works really well in the big trucks and trailers. I've wired a lot of big truck stuff and it is so easy because the different coloured wires are used to go to the same thing on every truck/trailer unit. White is ground, red is brake lights, green is left signal, and so on. After I wired hundreds of big trucks I became arrogant enough to try wiring an RV unit. Wrong Mistake! I'm a way smarter now.
