Rev Tex Devlle
He's workin' 4 da Lord, in a '46 Ford!
ok iam planning on cutting the springs in half, and using them like trailing arm,, i should say i will cut one in half and use it for the arms, and the other i will use for the buggy spring,, i have z'd the frame and this will lower me to 10 inches of ground clearance , at the bottom of the frame,, also the springs use to ride on top of the axle, i am going to move them under and build a saddle for them,,, i have meausered the springs, they are the same distance from eye to eye and the curve of the spring is the same,,, so will this work,, i am not runjning no big motor just a stock flatty with a f3 trans,, the rear end is high geared,, i was just wondering about, the sway facture,, my skill are good i have been welding since high school,, {trade school} and i currently build car trailers for a living,, have a good wire welder and stick also.. not worriedwith the welding,, just wanted to know what yall think about ,, leaf springs as traileing arms,, i saw it once on a rock climber jeep,, anyway advice please,, yes i know i could build trailing arms outr of tubing, but this is a real low buget build,, and the boss wont spare the tubing
