YoungBlood
I have heard from several rod builders that 2 link rear set up's aren't the way to go, which I can understand to some degree, a 4 Link would be preffered.
But whats the real problem with a 2 Link set up? If you ran a 2 Link with a Pan Hard bar and Coil Over shocks -- wouldn't that be enough for a 1800 lb (with driver) rat truck for rear suspension?
What is it that I'm not seeing? Is there an issue at high speeds? Bump issues? Longevity issues?
I'm sure this isn't the case, but does the pan hard bar not work as properly to avoid shifting of the rear?
I saw a Model T build that a guy used a 2 Link set up with Pan Hard bar at a car show. He wasn't there to talk to, but he obviously made it to the show.
Is a 2 Link with a pan hard considered a 3 Link???
I am new to this as anyone was, so I want to clear it up with y'all.
Thanks,
Tyson
Thanks,
Tyson
