If you want to check to determine if you have a fast ratio gear here is the formula.
With a cheap plastic protractor you can measure the actual sweep of the pitman shaft. Count the number of turns of the input shaft (full lock to full lock) and measure with your protractor the movement of the pitman shaft. Then using the following formula, you can calculate the ratio of your new gear box.
360 x Actual Input shaft Turns / Pitman (Output) Shaft Turns (in degrees) = gear box ratio
So you can fairly easily determine the gear box ratio with the above calculation. Note, if there is oil inside the gear box you will need a catch pan to catch the oil spurting out of the gear box ports. Or connect the inlet port to the outlet port to recirculate the oil.
Assuming that a your gear box is an original (Buick Roadmaster) and was not replaced during the vehicle lifetime, I actually have more confidence in a salvage yard part than some of the rebuilt or "remanufactured" boxes available in the aftermarket.
So if your sweep is very close to 87 and the input shaft rotates just a hair over 3 revolutions, you have a Saginaw fast ratio (12.7:1) power gear.
360 x 3.07 / 87 = 12.7
Full proof if you can still detect the alpha code ink stamp "FK" on the aluminum top cover or the aluminum end cover.
Jim
