meteorman
I am debating between an underfloor brake pedal/mc setup. $75 on speedwaymotors.
or a more expensive system that allows for underdash Kugel system, $240ish.
I am trying to keep costs low, so I am going to use my master cyl from the motorhome that I tore down and I'm using both axles/brake setups from the motorhome, but it was hooked up to a hydraulic boost system.
Am I ok to use the master cyl from the motorhome without the hydraulic system?
I am thinking I should be fine, because my rat rod is going to be much much lighter than the motorhome was and it has disc brakes up front with drum on the rear duals. The brakes are huge, and I'm hoping that the master without any boost will work fine. Can I just hook it up the the bracket under the floorboards?
What do I need for proportioning valves? check valves (or whatever they're called) , since it will be lower than the brakes? how do I know what specs I need for them?
thanks for your input!
