gold03
He lives in an "Altered State"!
Yeah, I know. That is a weird thing to do... but...
This is required when the callipers are intentionally swapped from left to right in order to create brake line clearance or to disentangle a brake line installation and routing.
The side to side swap puts the bleeder down and the brake line at the top of the calliper making it difficult to bleed the brakes because bubbles want to rise. Unless you do the following...
Find a piece of flat bar stock the same thickness as the rotor. remove the rotor and put the bar stock between the brake pads. Now turn the calliper and let it hang down in such a way that the brake line is rising toward the calliper and the bleeder is pointed up so the bubbles can come out of the bleeder.
Proceed to pump and bleed brakes as per usual.
Not mine, but see example below
When you are finished, reinstall the calliper and shoes.
