Bamamav
I'm looking for some ideas for a variable speed switch for a heater fan. My fan motor is 6 volts, I plan on running it on 12 volts as long as it will last
, I'd like to put in some kind of voltage reducing switch to cut the volts down and slow the speed down. Looked on Mcmaster Carr's site, didn't really see anything I thought would work. Thought about using the dimmer part of a headlight switch, but not sure if it could handle the amps of the motor, which I figure are pretty small anyways. It's not like it will be running all the time in a daily driver, I figure it might not be used but a few times a year.
Any ideas? Cheap and easy?
[ddd
