volt-a-drop
most of the classic truck sites carry them...
Does anyone know where I can get one of the old volt-a-drops that JC Whitney and the like used to sell? Thanks Rich
for converting older instrumentation to 12 volts.... I would check them...might even check at the old radio shack as well.... probably won't be shown for use in your application but they have something that would work...
Product # CX2036
ELECTRONIC VOLTAGE REDUCER$ 14.99 ea
Add to CartAdd to Wishlist
Classic industries.....
You can use a 7806 Integrated circuit that regulates 12v to 6v. Or Radio Shack sells a 7805 that reduces 12v to 5v. (which will make the gauges read a bit low) That and a diode or a couple resistors and you can boost it back to 6v.
Do a search '12v to 6v 7806'.
The IC needs to be mounted on a heat sync of some type.
worry
don't worry about it, lots of old threads get re-read and posted on.
ignore it and feel free to post where ever you feel like, might help others as it has helped me.
a lot of them still have good info, like this one.
l have been looking for a voltage drop to run my 6-V heaters in my rods and now l know rat shack or VW sites may have them.:D
Later :cool:
Now it is a 2 year old thread plus some
When I was into Dodge Sweptline trucks I brewed this up because the internal voltage regulator (5 volts) would fail and cook the gas and temp gauges. The factory VR is a thermal switch breaker point style deal and they stick causing 12v to go to the gauges.
You could use a 7806T instead of a 7805T and have 6v coming out of it.
This is fine for low amperage stuff like gauges or maybe a radio but I don't think it could handle a heater motor or wipers.
  • INSTRUMENT VR TEXT.pdf
    4.6 KB
    124.3 KB
