You are right, no one talks about. But I'll tell you what I did. After the roof was chopped I cut the top section off the door, and removed the same amout taken from the top. Then with the door on the hindges, I placed that upper part back into the frame. I figured out what I needed to add back to the length of the window frame section of the door. I took the chopped disgarded piece and re worked it to look like the upper section I needed, and welded it back in. I did a straight drop style chop, where you add a section across the roof to make up the length you need. Many people slant the posts back to reach the roof and leave the roof section alone. If this is the style of chop you are doing, you have to notch out a pie cut to slant the window frame back to match the frame.
