J
justsomeguy
Guest
This contraption I'm putting together has me a bit puzzled about what gear to run in the rear. Strictly street car, but hard usage. REAL hard. Here's the specs:
SBC or Gen IV - 383-408 CI
450-550 FWHP
6500 RPM Max Shift Point
Tremec TKO600 Trans: 1 - 2.87, 2 - 1.89, 3 - 1.28, 4 - 1.00, 5 - 0.64
12 Bolt Rear
33" Rear Tire
Probably around 1800-2000 pounds all said and done.
The OD in this trans coupled with this size of the rear tire is looking like I need a REALLY steep gear. I mean, 4.56's would put me at 3500rpm at 120mph!!! The dang motor won't even be into it's powerband by then. Should I just use the extremely light weight of the truck as a bonus and run a lower (numerically) gear?
What would you guys do?
450-550 FWHP
12 Bolt Rear
33" Rear Tire
