I thought I'd come back to this, as I recently plumbed my brakes and was pretty frustrated to find they simply don't work properly. long story short, I have a disc/drum master cylinder and they do not move enough fluid for a disc/disc application.
I've spent four days messing about with it, reversing lines, bleeding, testing calipers. I even connected front and back circuits together to 'share' the fluid flow, but for some reason the pedal sinks down and fluid overflows the rear smaller reservoir, obviously being pushed through the system somehow.
My TH350 trans has a fault too, no reverse and some other strange things.
The car was all but ready for a test drive, and everything was going well, motor fired right up, all electrics worked, so now I'm pretty fed up with the whole thing.
