I have a 4 wheel disc brake setup going on the hotrod. I have the under floor pedal assembly with a 7" dual diaphragm booster. I will use an adjustable proportion valve and residual valves.
I want the corvette style master cylinder with dual ports but I don't know if I should get the 1" or 1 1/8" bore master.
What is the general consensus?
They are the same price.
