I am starting to shop around for components for a rat-rod project. So far the only item I have is a 9" Ford axle with a Detroit Locker spool. But it is a start. I plan to use a 130-1940's truck cab with a shorty bed. Probably build my own frame. I like the idea of using a Buick straight-8 for power because the cool factor is there.
I would like to use old wire wheels too. Ideally they would have the large Ford 5-bolt pattern but I think that probably is not possible since all the pics I have seen of old wire wheels seem to have a small hub. So that is one question; are old style wire wheels available that use the large Ford 5 lug bolt pattern?
And my next question is concerning strength of the wire wheel. Granted, I will be using a Buick straight-8 which isn't exactly a monster motor, but will the wire wheels stand up to the torque of the motor? I think I may want to supercharge it or do something unique to make it stand out, but I am sure HP will be under 300. Should I be looking at different wheels? If so, what?
And I may as well toss this question in too. Is there an automatic trans that will bolt up to the Buick engine and give reliable service? I like stick shift but traffic around here has become so bad that driving a stick tranny is a real PITA.
Thanks for any and all ideas.
Randy
Randy
