kelseydum
I need new ends for my tie rod. I'm using the ford flat plate steering arms. The steering arms are meant to be used with the heim joints, and I would have to taper the steering arms by hand if I wanted to used the ford tie rod ends. My question is which is more safe, the heim joint or the tie rod end. The tie rod end is a little cheaper.
