IronRat
My problem:
My '51 BelAir has the front clip from a 70ish Camero grafted on to it. The Disc brakes set the wheels out from the sides to an unacceptable point. On an unmolested '51 chevy the center point of the tire is approximately center in line with the headlight.
Not easy to tell but there's a lot of camber to make the current wheels work and one pot hole will allow the fender to rip the tires up.
The current wheels have a 3 1/2" back space. I'd like to stay some what period correct if I can. The best I can do with Steel wheels is 4.5" backspace. I found Salt Flat mags with 4.25" backspace. Powder coated with hub caps vs. the mags about the same price and either would look good. I'm afraid 3/4 -1" increased backspace won't be enough after a proper alinement is made.
I'm having a hard time visualizing the difference Disc/Drum when thinking were the mounted tire will sit inside the wheel well. Would switching to front drum brakes move my wheel into the wheel well?
Is Drum conversion + more wheel backspace my answer?
Thanks
