Bamamav
Got my rear shock cross member bolted down, now I'm moving to the front. I am going to have to drop the wishbone about 2" to clear the trans pan. I plan on building a mount that bolts to the stock cup mounting bolt holes, and uses two lower cups bolted together to hold the wishbone. The original top cup half is made to the factory cross member. My mount will also have addition mounting points to keep it from collapsing due to the extra height.
My question is, when I take the bottom cup off, which way will the wishbone go, stay up or drop down? The front end is sitting with the weight on the tires. I just want to know so I won't be surprised if it does go down when it comes loose, I don't want a knot on the noggin!
