If you go on any forum, death wobble is one of the most often posted problems, it seems. Most of us have experienced it at one time or another.
There are so many causes, here are a few.
Caster. Too much or too little can cause it.
Toe in. Sometimes toe out actually will cure it.
Tires. Bias plies seem more prone than radials.
Wheels. A slightly bent rim can contribute.
Shocks. This is a biggie. Weak or ineffective shocks will not keep the wheels from bouncing up and down then it starts.
Wheel bearings. Need to be in good condition and adjusted right.
Kingpins need to be in good condition.
Wheelbase. Remeasure your wheelbase on each side and make sure your suspension is square.
Worn tie rod ends.
Steering box. Either worn or loosely adjusted. Make sure it it adjusted on the high spot in the center (it feels tighter there that is how you know)
Is your tie rod behind axle. If so, get a SoCal stabilizer it will definitely help.
Swap tires from one side to the other. Usually, the wobble starts with the passenger side wheel and transmits to the other wheel.
Out of round tires. If you can put your fronts temporarily on the back, do a smokey burn out and "shave" them more round. Or have a truck tire place shave them on a machine.
Once your car has serious death wobble you will never really relax again, wondering when it will happen the next time.
Post up some good pictures of your entire front end so we can better offer some suggestions.
