zing original ford frame
ripgut775
Jul 4, 2011
152
temple ok
whats up guys. i was wanting to use my original ford frame to z how would i go about doing that its a 46 ford f1 original frame and cab. also i want to go with a suiside front end if that changes up anything? thanks alot guys.:cool:
    112 KB
    49.1 KB
    52.2 KB
    63 KB
There are a few older ford truck builds in the Builds! Section that may interest you. Search or browse and you'll find 'em...
Well, the short explanation is that you block up the front and rear, cut the center section of the frame out, drop it down to where you want it, then fill in the missing areas with flat stock and strap steel to form new sections,
thanks bro ill post pics when i do my cuts. do i cut it a a 45 degree angle thats what i heard before? not sure tho. and also i heard of pie cutting it and laying it on top but i dont get what that means? thanks for the help guys
