61 Volkswagen V8 Single Cab Street Rod
The craftsmanship on this truck is simply amazing! [cl I'm sure there will be lots of finger pointing and head scratching to figure out what has been done to it! Great job! [cl
Thanks so much!
Todays progress
http://www.BenModified.com
Oh crap! That's no good! Going to build a heat shield? Wrap the headers?
Wrapped the headers where they immediately surround the motor mounts. If the mounts do not melt any further, then I will install new ones.
Also boxed in the area between the front of the radiator and the back of the side air scoop to keep hot engine compartment air away from the front of the radiator.
It was 98 degrees yesterday so I took it out on the highway and thru town and sat at quite a few red lights to see how it would do
From what I have read, this is an acceptable temperature, but I would still like to get it down a bit more. With the seat heaters, I have found that I will not need a traditional heater. I have been looking into a way to add some supplemental cooling for the really hot days via the unused heater hoses. I ran across a trans cooler for the dodge diesel from Perma-cool that is 10.5" x 21" with 5/8" tubing that I can place in the right side scoop. Not sure how it will work with antifreeze so I am going to call the company to inquire.
Any other suggestions?
The trans cooler manufacturer confirmed that the cooler will handle the pressure and the antifreeze. It arrived today and I have started the install. When finished, it will be boxed in and the scoop will force air thru it at speed.
