Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Tech Tips!
Old 11-27-2012, 02:07 PM
billy's Avatar
billy billy is offline
Motor mouth ratchet jaw!
Default make your headlights twice as bright cheap!
and cut down the chances of electrical fire
The headlight relay is a helpful upgrade. When I did it, I used an aftermarket relay and spliced in to the high beam and low beam wires under the
hood, to the headights. The objective is to have as little voltage drop as possible, between the battery and the lights. So that means large gauge wire to the relay(s), and tapping directly off the battery side of the solenoid. Get the headlight and dimmer switch, and all that small gauge wire connecting them, out of the headlamp circuit - the only contacts in the circuit will be the relay contacts.
a hot rod is whatever i decide it is.
"I don't practice what I preach because I'm not the kind of person I'm preaching to."
Old 11-27-2012, 07:47 PM
Did that with my Olds and my F100. Really noticeable on the F100 since it still has a generator.
Old 11-28-2012, 05:30 PM
billy's Avatar
even if it didnt make em brighter
it cuts out all that juice running through the switches
Old 11-28-2012, 11:16 PM
That's part of the reason I did it on my Olds. I tried to reduce as much juice going through the firewall as possible.
Old 12-30-2012, 08:01 PM
Willowbilly3 Willowbilly3 is offline
A *real* tin magnet
I make mine twice as bright by holding the dimmer handle back so the high and low beams are on at the same time
When logic and proportion have fallen sloppy dead
