Steering
Darksyde
Nov 6, 2015
123
Calgary, Alberta
So I'm rethinking my steering setup. Really wanted the cowl steering, had a mopar manual box, and everything pretty much built. But the inspection guys here do not like any welding on steering.
Can't do cross steer since I flipped my spindles suicide style due to the travel I need with my bags.
push pull style is still my only option, just need to move the box out onto the frame rails.
Looking for suggestions on a small steering box
Im thinking of trying to use my Mopar box(68 roadrunner) but I cant seem to find a pitman arm for it thats straight or doesnt have the rod end built into it.
Any ideas?
Found this one on the Borgeson site, Saginaw 920042
Used a similar Saginaw years ago, I think it was from an IHC pickup
Yup inspectors don't like helms. Issue with the rod end built into the pitman is how do you attach it to a tie rod. With a a threaded tie rod end I can thread it into a threaded rod and then insert the tapered end into the pitman. If that makes sense.
