1933 Pontiac
"I know there are different opinions and I respect them all however, I won't be chopping the roof or extending the front doors." (quote)
Somebody somewhere has to do something different sometime. Thanks for stepping up Old Iron. I love the way it looks.
I got some work done on the car today.
I cut 2 pieces of 1/8" aluminum to make a 16"x 36"x 9" gas tank.
Then put a radius die in my press brake, bumped an arch in the top piece and bent rounded corners on the bottom piece.
I cut and welded in a piece across the bottom for a baffle so the gas won't slosh back and forth
Tacked the top and bottom together
Then welded the 2 pieces together
I'll have to leave the ends open until after I get the sending unit, pickup tube and fill spout in.
This tank is the same shape as the original was and will bolt in the same position.
Nice tank. [cl
I really like aluminum (TIG welding the stuff especially) and plan to build one for my '38. I wonder if you have concerns with corrosion? Alcohol-blended gas is the reason I ask and your opinion is valued as always. :)
Thanks for the nice comments.
Doc, I've built several aluminum tanks in the past few years and have not had any give me corrosion problems.
The very first tank I built 3 years ago is in my 66 C10 and a couple days ago I had it on the lift. I seen no signs of a problem there either, inside or outside.
I would trust aluminum over mild steel any ole day.
I use aluminum fuel lines and high quality hoses too.
I was able to finish the gas tank after cleaning and straightening the shop today.
I got my wheels in a couple days ago too
I've go to save up a little geetus to buy the tires now.
So here's to all of you for now.
OI...are those Hoopty Wheels?? :eek:
They look like 22's or 24's next to it....not that would be terrible or anything...
Might have to get some 12" subs too...LOL...sometimes I crack myself up...:D
I'm glad you have a sense of humor.....
He he he
They are 18"
17" fronts 18" rears
Big ass amp to make it thump ;)
Although maybe we are on to something???? Rat Rod Hoopty's.....could start a whole new trend.... just have to figure out how to keep the rusty parts from falling apart from the thumpin.....
