Thanks for your comments, fellas. :)
Saturday: B-tard worked to rebuild the (original) trunk supports, while I dug back into the tailpan mess...
attachment.php
attachment.php
In the photos above, you can see the brass joint and a thick "cap" of BondoTM . (This can't be good.)
I ground some more, created more "shop flour" and discovered this flower...
attachment.php
What, in the blue flying blazes is that? (Censored for family viewing.)
B-tard returned to the scene of the crime and we scratched our heads for a minute or two... until the bulb lit...
A look inside told the tale...
attachment.php
15 more pop-rivets. The "patch" served no sensible purpose, except to cover three small holes. Those three holes (indicated above) once mounted a single taillight as seen below...
attachment.php
At that point, the flour grinder wore out his welcome and we tried a heat gun. Much to my surprise, a heat gun and a scraper is very effective... peels everything down to bare metal... though it's fairly slow going, we removed paint, primer and filler up and up the quarter panel, nearly to the sail panel.
It's obvious (now) the plastic sculptor "thickened" the entire quarter panel in effort to blend and conceal the patch, which he certainly did. :eek:
The crappy "high" patch will be removed and we'll fit the new tailpan with no other point of reference but the trunk lid.
attachment.php
attachment.php
dutch? The replacement panel is obviously a touch too wide, though it's loosely laid over the existing mess and less than an accurate representation. I believe we should fit and gap the tailpan according to the trunk lid.
Any and all recommendations are welcome. We're looking for perfection on this project...
I would tack weld the trunk lid in place and cut all crap out. Maybe make a few cuts before tacking ,which are hard to reach when the trunk lid is fixed.
Agree with dutch. Get the lid in place and square and everything up.
The lid will give you the gaps you need.
If you don't want to tack weld it in place I would mount it back on it's hinges and put in some internal bracing so that you can open the lid for access to your working area.. The gaps around the lid are what is going to draw peoples eye.
That looks like a decent piece of replacement metal . I wish I could find something like that for the Dodge.
You think your's is a mess.
I'll trade you.:p :eek: [ddd
That floor jack on the left holds up the trunk floor and that side. The entire area between both sides needs to be replaced. It will all have to be hand formed as I have never found a replacement panel
[P [P [P
Yee ouch, right now I'm feeling pretty lucky after seeing that mess, Dutch has the right advice on how to proceed. Crazy how much work went into patching that light mount, obviously someone had a torch, they could have just welded up the holes in the first place..... Torchie, I feel for you man, it's the downside of having a less common vehicle, hard to find organ donors and no repop parts....
Cant tell from the pics but if the panel fit is a problem, dont start wrestling it, just show it who`s boss and cut it in 2 or 3 pieces and go from there. :)
After looking at the photos in the early pages of this build, I am thinking that the replacement panel may be closer to accurate than it seems. Guessing that the back end may be pinched in a bit. I agree with Dutch that using the trunk lid as a guide is a great idea.
I'm still stunned... but I'm glad the car didn't have two taillights!
Torchie: Our tailpan was as bad as yours... before the tin, pop-rivet and brass Bondo King came to town.
We are fortunate to have a replacement panel, but it's not an NOS piece by any stretch of the imagination.
Thanks for your advice, fellas. We will work with the trunk lid as our guide, which brings to mind another issue...
When we first disassembled the car, the lid didn't fit very well. At the time, I thought it might be bent or twisted. Now I believe, the taller, thicker, plasticized quarter panel was the bulk of the problem.... hopefully, we'll solve that mystery this weekend...
Today, we removed the useless patch... drilled out the 15 rivets and carefully diced the patch up, hoping to avoid a cut-out...
attachment.php
coming along, you can see the original taillight's "footprint" and the three holes nearly brazed shut...
attachment.php
Some hammer, punch and dolly work along the way... brass completely eradicated...
attachment.php
I'll fill all those holes in a more sensible fashion.
Next, we laid the trunk lid in place... as we suspected, it's bent and twisted due to the dreaded "rear admiral." :eek:
Below, I stripped the lid's corner and found the evidence...
attachment.php
The pictures don't show it, but there was a large (filled) dent in the lower left corner of the lid...
So, the lid is buggered up. It's somewhat scrunched and 1/2" too tall, especially on the driver side...
attachment.php
attachment.php
Obviously, we need to iron and "stretch" the lid to fit properly... this should be fun...
You may be able to set that lid down on the ground and apply some downward pressure on it to get in back into shape and take some of the arch out of it.
If your tail pan area was in better shape I would do it on the car with a block under the DS corner.
Just some thought s from an old body shop man......
[P [P [P
Thanks Torchie.
Yesterday, we stripped more paint, primer and filler, including the entire trunk lid.
Here's a better look at the damages...
attachment.php
You can see the perimeter of the Wham-O and a deep, dark circle around the handle...
attachment.php
Handle area up close. Yep, that's 1/2" of filler, formerly supporting a Stanley garage door handle. Ha!
attachment.php
20 stretched nipples from the old "screw and jerk" slide hammer stunt.
attachment.php
On the positive, we don't have any rust holes!
Somebody hit the old girl pretty hard.:eek:
Whats the inner frame work of the trunk lid look like? Any signs of damage or repair?
As much damage as was covered up on the outside, it would be surprising not to see some wrinkles on the inside.
[P [P [P
