1962 f-100 disc brakes
tmgant
Nov 13, 2011
181
land-o-lakes , fl
Help, what rotors to use? Want to use 5x114 bolt pattern and the gm calibers. Need something that will fit in a 15" rim also. thanks Tobby
73-93 f100/150 rotors should work. Ford used the same bolt pattern on trucks for many years. 94 And up are metric rims AFAIK. You'll need the correct bearings and cups.
if by small pattern you mean 5 x 4.5" look for a kit that uses Granada rotors, they're listed if you look hard enough.
Granada rotors and the big GM calipers form 72 to 76 Impalas will give you stopping power plus.
A 62 will have the big pattern on it . its also a strait axle Correct ? and I think they went to a small pattern (car pattern) around 85 I think ?
