bluchvyguy
good compression ,started and ran moter sounded fine tore down just to do gaskets, and seems to have excessive movment at crank, is any ok on these 6s..
just where is the play you are talking about? up and down? Front to back?
front to back is crank end play that is determined by the thrust brg and should only be .005 to maybe .010 Is it from a stick or automatic?
